Kia Stinger getting an Italian voice!
Wake Forest
Wake Forest
2020 Kia Stinger GT2 (CERSIL/RWD)
[MENTION=321]robz32[/MENTION] did the unit come with a keyfob or something to control the valves/dampers? Or is that done via the mobile app?
Yes, it came with a module and a remote to control the valves
Sent from my SM-G960U using Tapatalk
Wake Forest
Wake Forest
Has anyone one tried to power the Tubi ECU via an electrical connection into the fusebox? And if so, does anyone know what kind of power this thing draws? The documentation provided calls for it to be hardwired to the battery for power. But that leaves the unit on all the time and could drain the battery if the car is parked for extended periods of time.
I'm going to drive to post the question to Tubi but I've sent questions before and haven't had a very good response rate from them.
Wake Forest
Wake Forest
Well, I hope this isn?t an indication of how the install is going to go tomorrow? And I definitely hope Tibi?s engineering standards are much higher than this; the ECU doesn?t even fit in the harness they provided. #FAIL
Not at all. Considering the exhaust is made to order.
Wake Forest
Wake Forest
Same mine took about 6 weeks. But partially because of when I ordered. European summer holidays see companies shut down for 2-3+ weeks in the late summer.
Wake Forest
Wake Forest
Surgery has begun! Thanks to the great guys at Providence Auto Care here in Youngsville, NC! (Bracing Hurricane Michael)
Niiiceee!!...Let us know where you end up tying into for the switched 12v for the ECU.
Keep us posted.
Post a video when you get a chance
Wake Forest
Wake Forest
[MENTION=321]robz32[/MENTION] we powered the ExCU directly to the battery as the install docs say. However I am in contact with Tubi support (Ivan in Germany) about power draw from the unit and I may eventually run power to a switches circuit in the fuse box.
Wake Forest
Wake Forest
OMG.... not sure it was possible before... but I think I love Natasha even more now!!!
For anyone near the Raleigh/Durham area... the guys at Providence Auto Care were phenomenal! (And I know the owner from church!)
2862-B Cedar Creek Rd
Youngsville NC 27596
We ran into some issues like the pipes did not fit quite right and wiring was a tad funky as one side was barely long enough and the other was twice the length needed.
