New York
Jhstinger
BSB
Brunei
Kia Stinger GT2 RWD
thanks! that looks pretty awesome and the concave looking sweet. Probably asking a bit too much here, can you do a photoshop at the same angle for Niche Targa M130? Comparing these two wheels at the moment. Thanks in advance!
GetYourWheels
Vendor
Santa Fe Springs
Santa Fe Springs
Overland Cayenne Diesel
If I had to chose, definitely go for the Vertini RF1.2 wheels just for quality reasons. Plus side, the Vertini RF1.2 is also lighter.
Harrisburg
Has anyone found a set of rims that fit the stock tires? I have the 19? staggered rims and want to try to keep the tires if I can.
Sacramento
Check on tirerack.com and tires.com, there are plenty of wheel options.
GetYourWheels
Vendor
Santa Fe Springs
Santa Fe Springs
You can pretty much use any 19x8.5 and 19x9.5 in the market.
But if you absolutely want 19X8 and 19X9, I can make that happen.
So for those of us looking for a square setup without fender modification or rubbing, we're looking at 20x9 as the largest size due to front clearance?
I have a GT2 AWD with the factory 18in all-season tire package and the gap is absolutely horrendous.
I am not planning on lowering my car at all, so I'm leaning towards a 20x9 or 20x8.5 with 255s on all corners. Anyone trying anything similar? Looks like we can do offsets between +32 and +40, wondering if we can do 40 aspect ratio tires or if we need to stay at 35 with the 20s up front.
Bueller? Bueller?
Physicks
San antonio
Hey everyone.
New stinger owner and new to the forum.
Just ordered wheels from a local shop.
Their ?research ? shows
20x9 et 35 on the front and
20x10.5 et40 works on a niche methos.
Eibach pro kit springs on a Gt Rwd.
Some of the posts on this thread have me worried that the rears won?t clear the strut with the offset.
Tire is a 275/30r20 toyo for the back.
Is the any reason this won?t work?
Thanks in advance
San Antonio
Hey bro I'm in SA too. Those wheels specs should work as they're similar to the Genesis G80.
Hey everyone.
Thanks in advance
Hey everyone.
Thanks in advance
If you search you will see that people have gone up to +45 with 20x10.5 with no issues.
GetYourWheels
Vendor
Santa Fe Springs
Santa Fe Springs
Bueller? Bueller?
20X9 +35 would be about the offset I would do to be flush for stock height but enough to clear the brakes. For your tires, 255/30 would actually be closest size to your overall rolling diameter but we have successfully ran 245/35/20. 255/35 may be a bit oversized and run into issues of rubbing on fender liners during turns and 255/40 would just be way to oversized.
Hey everyone.
Thanks in advance
20X10.5 +40 would stick out a bit on stock height. 20x10.5 +45 that we run is already pretty aggressive looking at stock height
